Logging Winch
   / Logging Winch #1
ascurtis
'm looking for a used logging winch for my JD4320 3-pt hitch. I need to clear an old roadway. any size or brand recommendations? Thanks. Located in the New England.
   / Logging Winch #2
i run a fransgard v-3507 3ph pto winch on my kubota b7800 for my fire wood business. it works GREAT. i was shocked by what i have seen it do on my 2500lb tractor. the v-3507 can pull over 7000 lbs and the tractor weighs much less. i first was worried about strain on the 3ph, but so far no problems what so ever and i have used it alot. the dozer blade anchors the unit into the ground and that helps hold it and takes most of the pulling strain. the fransgard models have a top pull and also a lower mounted pulley to lower the center of gravity and take the force off the top link of the 3ph and put it down to the lower 2 arms. i usually use it on the lower pulley but if i need to keep the front of the log off the ground or pull up over a mound i use just the top pulley. the lower pulley just swings around the cable so you can use it any time easily. i don't know the specs of your john deere, but fransgard also makes other models bigger and smaller. no matter what brand you choose, if you never used one before be carefull. bad things can happen fast if you don't know what to look for. the pulling speed of the fransgard is about 5 feet per second. and never do side pulls. always pull in a straight of a line as you can. good luck with your winch shopping.
i see you are in new england and i came across this web site. they sell the norse winches and ship free to the new england states. here is a video of their 3ph winch
http://labonville.com/Videos/v7.htm
farmi also makes a winch and i have heard good things about them as well.
as far as a used one i don't know where they are. a new one is going to be between $2000 and on up. i paid $3700 for mine and it was worth every penny. it has already more then paid for itself with the increase in product i have been able to put out.
   / Logging Winch #3
I have a Farmi which has given me very good and reliable service. They are basicly bullet proof. They also have good parts availability if you find one that needs work.
Your 4320 will run anything that will fit on it. A heavy duty winch would be the best match
   / Logging Winch #4
Are these made to skid the logs after they are pulled to the tractor? Meaning can you get the end up out of the dirt and drag it with the tractor to a cutting area?
   / Logging Winch #5
Yes, and they do it about as safely as is possible. The blade that namesray described stabilizes the tractor when you're winching and serves as a guard when you're driving with the load, preventing the butt ends from snagging on roots, rocks, etc. I've been scouting for a used one and considered building one myself for some time now. I would find a lot of uses for it besides bringing in the wood.
   / Logging Winch #6
I have skidded a bunch of timber with a 24 hp SCUT and a receiver hitch adapter on the 3pt. I have a short (12-24") telescoping boom lift arm that pins to the top link connection. Has worked well for what it is.
I'm also considering "improvements" to this set up, by adding a 12V electric winch to the boom arm, and a pair of feet on the draw bar to help anchor the tractor while winching.
I know it won't be as robust etc as a PTO winch, but............ Hope to have it all come together for a LOT less $ than a dedicated logging winch.
What ever works the best for the situation is the best to use.
Good luck
   / Logging Winch #7
Good luck
i will almost agree maybe a 3ph pto winch might be over kill just to clear an old roadway, but i don't fully know your situation either. before i bought my fransgard pto winch i had a friend of mine rig me up an electric 12v 3ph winch for my firewood business. what we did was make a A-frame for the 3ph and bolt a chicago 12v electric winch to the A-frame at the bottom. run the cables from the battery at the front of the tractor to the back in condiut under the tractor. the chicago electric winch had 3000lbs pull and bought from harbor freight. all together i had about $230 into it. $110 to friend for A-frame, $110 for winch from harbor freight, and $10 for longer battery cables. i used that 3000lb winch for 3 years and did ALOT of firewood with it. it was slow and only had 50ft of cable but it could pull some logs that i could not drive the tractor close enough to just hook a chain to. that winch still works. if i knew how to put pictures on here i would do it but i am not good with computers or cameras. the only reason i upgraded to a pto winch is because my business was growing and i operate on VERY steep hills in northern pa. being able to have 130ft of cable and 7000lbs of direct pull is a huge benefit to me when on those steep hills. the logging roads are barely wide enough in some areas to get my small 30hp tractor with loader sideways enough to pull the logs up onto the road. no way i could get to those logs any other way. so that is why i invested into a pto winch. just giving you other ideas that may or may not help. have fun shopping around and sounds like a fun project. stay safe.
   / Logging Winch #9
I, too, have a wallenstein. I haven't really pushed it, but so far I really like it. I'll be doing a review of it and my self releasing snatch block soon. When some snow leaves, my new valve is on, etc.
   / Logging Winch #10
This is a good thread as it is bringing out the various needs of differentiated small machine skidding. The expense of a dedicated pto driven winch is not a small one for most. In my mind one has to be producing a good amount of firewood or mill stems for it to be cost effective. Other needs commanding some type of winch are the characteristics of terrain. A winch in hilly areas may mean such a difference in a safety quotient that it becomes a mandatory equipment choice. For the occasional user on undifferentiated terrain, a pto winch may be a bit of overkill. A mounted electrical winch may be a more cost effective method in this case and used only when being unable to get in close with the tractor for a 3 pt pick up. It does not matter if this type of winch is mounted on the front or back of the tractor since the winch would not be used to skid with. There are advantages of the pto winch and if one plans to live in an area for a long time and is consistently making small amounts of firewood (4 to 10 cords) per year, the winch minimizes the beating up of the tractor as most wood is coming to the tractor instead of the other way around. On the flip side, many a cord of firewood has been skidded up to landings with just the hitch point of the tractor.
KUBOTA L2350 TRACTOR (A51243)
KUBOTA L2350...
2001 STERLING WATER TRUCK (A51243)
2001 STERLING...
2013 Cadillac ATS (A50324)
2013 Cadillac ATS...
1274 (A50490)
1274 (A50490)
2018 BIG TEX 35+5 T/A GOOSENECK (A50854)
2018 BIG TEX 35+5...
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
