Long 2610 wheel bolt torque
   / Long 2610 wheel bolt torque #1
dwilliams35
I'm short one manual and kinda need this in a relative hurry: my boss's Long 2610 is snapping some wheel bolts,and we need to find out if anybody's got an actual torque spec for these lug bolts: The rears are 14mm x 1.5, the fronts are 12mm x 1.5.. Rears seem to all be grade 10.9, the fronts have 11.9 stamped on them, standard tapered-head lug bolt. Any help will be MUCH appreciated...
Thanks!
   / Long 2610 wheel bolt torque #2
Thanks!
These values are takened out of the 2610 op manuel. I also checked in the 680 op manuel which is same power train. Rear bolt torque is 190 ft. lbs. ( 258 Nm ). Front wheel bolts are 90 ft. lbs. ( 122 Nm). Check all bolt torque after one hour of operation, then once daily until they remain tight. Good luck- Trac
2016 Ver-Mac S/A Towable Trailer Message Board (A49461)
2016 Ver-Mac S/A...
2012 MACK CHU613 (INOPERABLE) (A50854)
2012 MACK CHU613...
2013 CAT 950K WHEEL LOADER (A50854)
2013 CAT 950K...
PENDING SELLER CONFIRMATIONS (A51219)
PENDING SELLER...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
