Long 350
   / Long 350 #1
robert109
fredericton,nb,canada
ford 7000,long350,ford4000,mf180
After cracking the injection lines at the injectors to bleed out the air and the engine started .I tightened the connections but now have a leak at one of the injectors where the line connects to the injector.I have tightened the pipe connection but still leaks some.What should I do now ,Is there a brass-copper washer there that can be replaced?...any suggestions ?
   / Long 350 #2
U might be able to take it loose & use some sand paper on the end of the line.. somehow they get rusty.
Just BE SURE & blow it out REAL GOOD.. u don't want any of the grit getting pushed into the injector..
OR.. buy another line..
The ends of the lines are a crush seal.. they'll only take so much crushing before needing replacement..
I tell my customers, "just snug it up.. u can always go back & snug it up more.. BUT if u crush it from the beginning & it leaks, your done"..
2015 INTERNATIONAL 4300 26 FT NON CDL BOX TRUCK (A45679)
2015 INTERNATIONAL...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A50046)
2020 FREIGHTLINER...
2013 GAYLEAN  130BBL (A48992)
2013 GAYLEAN...
(1) 12ft Livestock Panel with 4ft Walk Through Gate (A48837)
(1) 12ft Livestock...
2012 CHEVROLET 3500HD 4X4 TRUCK (A50046)
2012 CHEVROLET...
2005 Ford F-150 Pickup Truck (A48081)
2005 Ford F-150...
