Long DTC 3oo will not stay running
   / Long DTC 3oo will not stay running #1
loafersglory
Nottingham, NH
Long DTC 300
I have a Long DTC 300. Ran out of diesel fuel. Refuled and purged air from fuel lines. Tractor will fire and run if igniton switch is held in start position. When switch is released engine quits. I have noticed that my fuel gage is not working. Pulled out sender assembly, not hug up and does not appear to be damaged. Is there a connection between fuel gage/assembly and ignition? Thanks, Allen R.
   / Long DTC 3oo will not stay running #2
Their is no connection between the fuel gauge and the starting- running of the motor. Sounds like the fuel system still has air in it. On the side of the fuel filter assembly, their is a knob. Their is three postions, on, air, and off. Turn the knob to the air postion. ( their is a bleed tube with a rubber cap on top of the fuel filter. Make sure you remove this cap so fuel can come out. You will also need a pail underneath to catch the fuel.) Run fuel until no air bubbles are present. This may take a couple trys. Move the knob to on. Run the starter and it should fire. Good luck Trac
Case Titan 3530 (A55218)
Case Titan 3530...
CATERPILLAR 615C MOTOR SCRAPER (A51406)
CATERPILLAR 615C...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
2013 Mitsubishi Fuso FEC72W 18ft Dovetail Flatbed Truck (A51692)
2013 Mitsubishi...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55788)
2013 Ford F-150...
