Longtrac 520/530
   / Longtrac 520/530 #1
danny11b
Bronze Member
longtrac 528, long 610.allis 5030.5040,5045.mitsubishi mt2001.allis 185,caseinternational 234, white 2-105
I have a Longtrac 520/530DTS works well. could I get information on EXACTLY what it is/whereand how to find parts for it. Is it the old stule long 2510? HELP!!:confused2:
   / Longtrac 520/530 #2
The 520 is the old 2510 from Romania. The 530 model was built in South Korea. Which one do you have? Trac
   / Longtrac 520/530
I have the 520. I couldn't remember if it was the 520 or 530, but I knew it was made in romania because I have an allis 5040(romania), and a 5045(italy)both are on the same design as the 520. They have both given me good service and the longtrac 520 seems to be of the same stripe. Will the parts for a 2510 fit the 520? Thanks for your reply/information.
   / Longtrac 520/530 #4
The 520 replaced the 2510 in 2002. In order to become compliant with emmission stamdards in the U.S( teir II), they had to redesign the engine slightly to pass. The piston top ring was raised to reduce smoke on start up. They also changed the fuel injection system to a Delphi brand to comply. Some engine parts will fit off the 2510 and some will not. From the clutch reward is the same as the 2510 except for the 3 point and remote valve whicch replaced the Romaniam one with and Italy made version. We have a couple wholesalers that have a good sucess rate at filling our orders. Their are also companies on the internet that advertise Long parts. Trac
   / Longtrac 520/530 #5
I have a long track 520 and the clutch just stopped working on the drive part .
   / Longtrac 520/530
was it in use when it occurred, how many hrs on it? Could be a simple clutch falure, could have stripped the "eye" out of the clutch, could have broken/stripped the trans input shaft.
2011 Ford F150 (A50515)
2011 Ford F150...
R&G Trailblazer 1000Gal 28% Applicator (A52349)
R&G Trailblazer...
2017 Ford E450 Super Duty 20 Passenger Bus (A47384)
2017 Ford E450...
2022 John Deere S780 Combine (A50657)
2022 John Deere...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
UNUSED CFG Industrial MH12RX Mini Excavator (A47384)
UNUSED CFG...
