fish6942
We have about 2-3 acres of lawn where I need to loosen the soil and smooth it some before I reseed the whole thing. I'll also be looking for some type of pull behind drag of some type for the final smoothing.
Wifey also wants me to look into getting a tiller for her new garden. I'm hoping to be able to do an adequate job with a disc so I can avoid the expense of a tiller (either walk behind or PTO).
Questions on the application:
1) Will a 4' disc work for the lawn work? The topsoil is mostly good black dirt.
2) Some units have smooth discs and some have notched discs. I'm guessing the notched type will do a better job of breaking up topsoil and vegetation?
I've located a used 4' 3PH tandem disc with smooth discs. It sounds like it's pretty well used but for the lawn work it's only a one time use. Here are some questions on that:
1) What should I be looking for when I go to check it out?
2) How easily should the discs rotate?
3) Are there any adjustments on these?
Thanks so much!!
Thanks so much!!
