Looking at new ZTR mower
   / Looking at new ZTR mower #1
Geneha
Excelsior, AR
Kubota B7500
I am thinking about upgrading my 60" 26hp gas mower to a diesel one. Now that I have a diesel tractor I want to have similar fuel to buy. This would also the last mower I would have to buy. This should last me 20+ years or so. Another advantage to the diesel engines is that they are water cooled..
I am looking a 2 diesel ZTRs.
1) Kubota ZD326 60". A feature I like is that the cutter deck is driven by a drive shaft and the only belt is the one that drives each cutter blade. Another option is rear discharge. 13 gallon fuel tank(s). CON: $13,200 and some change
2) Bad Boy Compact Diesel 61". Being from Arkansas the BB are made here. The Kubota has a 26hp 1.0L engine. The BB has a CAT 28hp 1.1L engine. (No biggie). 18 gallon fuel tank(s). CON. it has more belts and no drive shaft to run the cutter deck. BB has rubber isolation on each wheel so a better ride and some of our land is kinda ruff. . PRO: Price $11.500
Both are colored orange so no color conflicts.
My other mower is about 600 lbs and both if the above are about 1500 lbs each. I have mowed over the leach line with the tractor so the ZTR weight should be a issue mowing over the leach line ( I hope)
Any comments on either brand would be welcome.
Thanks in advance.
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2003 FORD F350 XL SUPER DUTY DUMP TRUCK (A51406)
2003 FORD F350 XL...
2007 Ford Expedition EL Limited 4x4 SUV (A53424)
2007 Ford...
2018 John Deere 460E Articulated Dump Truck (A55218)
2018 John Deere...
2004 Ford F-250 Liftmoore 2,700 LB 1 Ton Crane Service Truck (A53422)
2004 Ford F-250...
