Looking for bolts
   / Looking for bolts #1
Fishguy
Northeastern NC (flatland)
NH TC30 HST
I have a King Kutter 6' FM. I am trying to replace the stock wheels and tires with "no flats". When the new ones came in they are bit wider than the originals. I was able to spread the forks out to fit the wheel in but now the axle bolts are to short. The stock bolts are 3/4 x 5. I am trying to find some that are an inch longer that does not consist of mostly threads. Any ideas? I've already been to the big box stores and Ace with no luck. Is there a good online store?
Any help would be great. Thanks in advance,
Steve
   / Looking for bolts #2
"Fastenal". If they don't have it, They can find just about anything you need.
   / Looking for bolts #4
Steve
McMaster-Carr has heavy head bolts with limited thread. I have some 3/4x 6". They have 4.5" shanks. Youll probably have to buy a lot of 5 rather than single bolts.
larry
   / Looking for bolts #5
Steve
Steve, I have run into this problem before and what I do is to buy a longer bolt that has the closest straight shaft to what you need and cut the extra threads off with a cut off wheel on my disc grinder. Then a little paint to keep it from rusting.
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
2009 Freightliner Columbia 120 Winch Truck, VIN # 1FUBA5CK39DAM2731 (A51572)
2009 Freightliner...
NEW  Ripper Shank (A53002)
NEW Ripper Shank...
2006 TerraGator 8104 (A53472)
2006 TerraGator...
2007 International 7500 sba Flatbed 6x6 Truck (A52384)
2007 International...
