I've found a YM186D not too far away. I'm curious what I should be looking for if/when I go see it. A general inspection, confirm what works what doesn't, check the oil and transmission for water, PTO, 3-PT, etc. Where would I find the dipsticks for the oil and transmission fluid? This machine does not have a loader though I could sorely use one. Can this machine handle a loader? What type/size/brand.
These are an excellent model. Yanmar's smallest with Powershift. I have two of them. Lets just say both of them were better looking 35 years ago but both run flawless.
The first one, no loader, dyno tested to match the original specs. The second one seems similar. Both start instantly.
The transmission dipstick is on top of the left axle housing, a small button and hard to see.
Transmission range three seems to be an overdrive for transport. Both of mine whine some in range three but this doesn't seem to be a problem. That's the only thing I can think of that might make you wonder what is going on. Otherwise just check for all the usual stuff. I think only abuse like overheating or running out of oil could harm these but normal hours won't wear it out.
Check for slack in the steering box, one stored outdoors will eventually rust the steering box bearings and need the steering box overhauled. Parts are available. And check if the bolts that secure the adustable-width hubs onto the axles are snug. That's a simple test indicating if the seller kept up on his maintenance since they need to be tightened monthly or so. I can't think of anything else that isn't obvious when you look it over.
A lot of them were sold with OEM Yanmar loaders (I think actually US or Canada made). And I think it is a lot less expensive to buy one that already has a loader, compared to adding a loader yourself. They handle a loader fine assuming you ballast as needed.
You'll love it.
A guest who wanted to play farmer for an afternoon. She helped harvest apples.
Watering new trees last week. Trailer is 2600 lbs loaded, but down to less before I feel comfortable taking it down grades like here.
The front bin was to harvest some family pears while I was down in the back of the apple orchard.
