Loose Swiper O Rings on Loader Cylinders
   / Loose Swiper O Rings on Loader Cylinders #1
Redbug
Veteran Member
Columbia, SC
Kubota L3830HST
Hi Guys,
I have a 723 loader on my L3830 and have noticed that occasionally an O ring will come loose and stay at the end of the cylinder arm. It is the first O ring you see when looking at a cylinder...where the arm goes into the cylinder itself. I have reglued them back onto the cylinder on occasion, but they occasionally come loose, again. I have noticed a few loose on the dealer's lot also, and was wondering if the O ring is important enough to make an issue or just ignore it? It does not hold any pressure, just seems like a "swiper".
   / Loose Swiper O Rings on Loader Cylinders #2
Redbug said:
Hi Guys,
The rings you refer to are probably not the swiper O rings but rather the O rings (as we have been told) are simply seals used when the cylinders are painted.
Thank You Rat! I was not sure and now I don't have to worry. You would think the dealers would just cut them off before selling the loader and avoid the issue altogether.
   / Loose Swiper O Rings on Loader Cylinders #4
When I got my tractor home I had the same thing. I tried to push
them back in also. I noticed others were the same. Thats the way
they are:)
   / Loose Swiper O Rings on Loader Cylinders #5
I had similar concerns, and ask my dealer -- he said they were there for painting purposes only.
2010 L3 GENERATOR SET (A51222)
2010 L3 GENERATOR...
2001 STERLING WATER TRUCK (A50458)
2001 STERLING...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
2018 John Deere 60G Excavator (A50490)
2018 John Deere...
Unused Delta Crash...
2012 MACK GU713 DUMP TRUCK (A50459)
2012 MACK GU713...
