Loose Transmission drain plug
   / Loose Transmission drain plug #1
Propjob
Bronze Member
Seacoast NH
JD 2305
Here! back again after a busy summer. The brush hog ran quite well with chains but needs a couple of small mods. Brought the tractor home from the field and noticed a small leak in the driveway. I found the pipe plug behind the transmission /Hyd filter was loose and leaking. Tractor had its 50 hr check up 2 years ago and the fluid in the sight glass was always full. I had to tighten the plug and add 1.5 gallons of lo viscosity Hy Gard. The only change this year was brush hogging. Has any one experienced loosening of drain plugs before?? I guess this is a lesson!!
JIM
   / Loose Transmission drain plug #2
I always use a little Teflon tape on the top of the threads if they are not real tight, another trick that works well is to tighten it up, back it out 1 turn and apply a dab of low strength locktite to the threads and retighten. The tiny bit of locktite will keep it from vibrating loose during harsh sustained operations like brushog use. I find the use of locktite is really critical on machines like trenchers that literally try to shake themselves apart.
   / Loose Transmission drain plug #3
And pipe plugs can be tightened too tight...so be careful.
Or is this a plug that has an 0-ring around it for a gasket?
No just a pipe plug with a square head... Sits behind the filter mount on the 2305! Good point on the loctite.
   / Loose Transmission drain plug #5
I can't imagine there would be any vibration to loosen a properly tightened drain plug. I suspect it was not snugged up to begin with.
UNUSED AGT KRW23 WHEEL LOADER (A51243)
UNUSED AGT KRW23...
UNUSED FUTURE SKID STEER STUMP GRINDER (A51244)
UNUSED FUTURE SKID...
300-gal Poly Sprayer 60ft Boom (A52128)
300-gal Poly...
John Deere 825i Gator (A50514)
John Deere 825i...
Land Hero Mini Skid Steer (A50514)
Land Hero Mini...
Quick Attach Pallet Forks (A47384)
Quick Attach...
