Lost key fob
   / Lost key fob #1
RalphVa
Super Member
Charlottesville, VA, USA
JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
I somehow managed to lose the key fob to my wife's Mazda3 from my fanny pack.
Ordered a new one from Amazon for $37. It looks just like both the fob to the MX-5 and the 3. The 3 does not employ a real key when its fob battery goes out but does have a key for the glove box, doors and trunk. Whereas, the MX-5 employs the key in the end of the fob also for the ignition if the fob battery goes. So, I was wondering whether the new key fob would indeed work on the 3. (You just hold the fob up near the keyless ignition button to start the 3 when the fob battery goes out.)
Went to a local (Albemarle Lock & Safe) outfit and had the reprogramming done. It took a bit longer than usual; so, it was $100 instead of their usual $50 they charge. Last thing they did was to cut the key on the key fob (using my wife's fob key).
Someone on one of the 3 forums suggested programming the MX-5 to be the same. Think he overlooked the key in the key fob. Would have had to change out the locks that the key fob key works to do this. No.
The wife has pinned both my Mazda fobs inside my fanny pack with safety pins and a rubber band, to keep me from accidently dragging out the fob when getting other stuff. Normally, I plain don't use either key fob. They just sit in my fanny pack.
Ralph
   / Lost key fob #2
My 2018 BMW R1200GSA has keyless ignition. Should the battery in the fob go dead and the spare battery I carry be dead - there is a plastic key that can be held next to the receiver to start the motorcycle and ride it home. A new keyless ignition fob and reprograming - - $350.
   / Lost key fob
They said it would be $500 if we'd have lost both fobs.
Ralph
   / Lost key fob #4
I've NEVER lost a key to a vehicle - but with my luck - if I ever do - its bound to be one of these expensive ones. Never going to be a tractor key that comes in at a dime a dozen.
   / Lost key fob
Ralph
Correction: it was only $50 at the Lock & Safe place. Wife was counting the $37 for the fob and rounding up.
   / Lost key fob #6
Fanny pack? People still wear those?
2014 John Deere 8360R MFWD Tractor (A50657)
2014 John Deere...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A51039)
Kubota 24in Quick...
2014 Ford F550 Crane Truck (A50323)
2014 Ford F550...
2018 Caterpillar 416F2 4x4 Extendahoe Loader Backhoe (A50322)
2018 Caterpillar...
2013 FOREST RIVER WILDWOOD BUMPER PULL CAMPER (A50854)
2013 FOREST RIVER...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
