low hydrolic level bx 24
   / low hydrolic level bx 24 #1
riverhunter
Well its sunday and got a full days work for tractor. Checked fluid levels and hydrolic fluid does not even reach stick. No way to get kubota fluid today on sunday, is there some kind I can add without damaging tractor. Thankyou.
   / low hydrolic level bx 24 #2
If you are checking the fluid level w/both the BH & FEL on make sure that the BH is in the transport position w/the outriggers up and the FEL is flat on the ground. You can get a low reading if the FEL is raised and/or the BH's outriggers are down or the dipperstick is extended.
The best way to take a reading is put the BH into transport position, insert boom pin lock in & raise the outriggers, lower the FEL, shut off the engine then cycle both the FEL and BH's joysticks to relieve all the pressure then take a reading.
When you dismount either make sure you relieve the pressure before you disconnect the fittings.
Your BX24 comes w/SUDT and you don't want to mix in any other type with it.
Volfandt
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
2013 AMSIG S/A Solar Towable Message Board (A50322)
2013 AMSIG S/A...
2008 BMW 535xi AWD Sedan (A50324)
2008 BMW 535xi AWD...
2013 VOLVO VNM TANDEM AXLE DAY CAB (A52141)
2013 VOLVO VNM...
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
