quicksandfarmer
Elite Member
I have a Jinma 354 which I use mostly for mowing. I usually use a 60" rotary rough mower, and I like to set the two-speed PTO at 720 RPM and the engine at 1650 RPM, which gives me 540 RPM at the PTO. (I know you're supposed to run at full RPM's, but this way seems to work fine, and is quieter and smoother so more pleasant for the operator, me). Configured like this I can mow all day in 4L and the oil pressure needle stays right in the middle and the temperature stays steady.
I recently bought a 68" flail and I quickly realized it needs more power than the rough mower, at 1650 RPM the engine stalls if I hit patch of thick grass. So I pushed it up to 2200 RPM and shifted the PTO into 540 RPM, and dropped the gear down to 3L. This seems to work OK, but after a few minutes I noticed that the oil pressure had dropped down so that the needle was right on the border of the red. It's still in the green, but very close to red. Temperature is fine.
Switching back to the old mower the oil pressure is fine.
This worries me. I would expect the oil pressure to be higher as the engine RPMs increase. Is this a sign that I'm asking too much of the engine? Is there a risk in running at this low an oil pressure, even if the needle isn't quite in the red?
Thanks.
Thanks.
