Low power steering / transmission oil pressure warning display
   / Low power steering / transmission oil pressure warning display #1
CattleTx
Central Texas
JD 7330 JD 6420 CIH Farmall 105U MF383
I have a 2012 Case IH 105U which is essentially the same as a NH T5060. It has a 12x12 Synchro Power Shuttle transmission with the electro-hydraulically controlled PTO. This week when doing some shredding I started getting the "low power steering/gearbox oil pressure warning indicator (transmission oil symbol and steering wheel symbol) on the console display when I first engage the PTO in neutral at idle. As I increase the rpm's the warning indicator goes away and every thing operates as normal.
The tractor has 1125 hours on it. I bought it in 2015 with 871 hours from a dealer where it had been traded in on a larger John Deere tractor. Since it was near the 1000 hour mark, I had the dealer change all the hydraulic fluids and filters before I took delivery.
I saw an old post on the New Holland forum where an owner of a TN75SA had that display came on and stayed on. RickB suggested that it might be a bad pressure switch which was the problem. I will check the pressure switch on mine (if I can find it). Any other suggestions as to where to start this diagnostic search?
   / Low power steering / transmission oil pressure warning display #2
I worked on a JX1100 which had that symbol displayed, changed transmission fluid and filters. Turned out to be the pressure switch. I posted some pictures, i will try to find one for you.
2005 Hummer H2 4WD SUV (A50324)
2005 Hummer H2 4WD...
2024 John Deere 6110M (A50120)
2024 John Deere...
2014 Homemade 16' Gooseneck (A50121)
2014 Homemade 16'...
2024 Doosan DX140LCR Hydraulic Excavator (A50322)
2024 Doosan...
2011 GMC Sierra Pickup Truck, VIN # 3GTP2WE36BG213306 (A51572)
2011 GMC Sierra...
New 20ft 5/16in G70 Tie Down Chain (A50323)
New 20ft 5/16in...
