Lower radiator hose Jinma 284 (Yangdong)
   / Lower radiator hose Jinma 284 (Yangdong) #1
ctusdenny
Cashmere, wa
2005 Jinma 284
My lower radiator hose sprang a leak this weekend. Top hose looks fine. I've searched around the forum here for a cross reference # to buy one locally at an auto parts store. The only thing I could really find was a Prestone part # 80070. This was from a post back in 2009. Wondering if anyone has a more recent find they can share? I'm looking for something close in dimension that I can trim to fit.
Also, I noticed when taking the old hose off that it's a pretty "rigid". Has anyone had an issue trying to get this hose back on without removing the radiator, etc?
Denny
   / Lower radiator hose Jinma 284 (Yangdong) #2
Yep they are hard to get on/off. Not sure if you have installed a Radiator/Coolant heater but that makes it a bit worse... I have me a KATZ block/coolant heater installed in the short straight section on mine.
same old hose from back in 2002. Maybe take it off and take the hose to autoparts store for a eyeball fit check.
Mark
Mark
Thanks, Mark. Haven't installed a heater. Maybe something to consider, though. I'm going to take the old hose into the local auto parts store and see if I can find one that's close, like you say. That's probably easiest it seems. Thanks.
   / Lower radiator hose Jinma 284 (Yangdong) #4
   / Lower radiator hose Jinma 284 (Yangdong) #5
do the upper one at the same time. You'll be glad you did.
Update:
Went to NAPA and searched around their hose bin and found a close match. I'll post the number for reference tomorrow. Anyway, the hose I found was quite a bit more flexible. That helped with install quite a bit vs. the stiff, stock hose. It does feel a little less robust, so I might have to change it sooner. No problem since the hose I found was only $9.
Had the hose replaced in 10 min. Replaced the upper hose as well. Figured get them both at once.
2019 KENWORTH T800 (A53843)
2019 KENWORTH T800...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A53473)
GOODYEAR SET OF...
CABINET OF HOSE ENDS (A53843)
CABINET OF HOSE...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2012 DRAGON 8,400 GAL TRAILER (A53843)
2012 DRAGON 8,400...
JLG E300AJ (A50123)
JLG E300AJ (A50123)
