Truautorepair000
Hey, just looking to be pointed in the right direction. I have a 2021 mt122 tlb, and it's fine, as is. I use the backhoe a lot, and could benefit from more gpm from the hydraulic pump. I want the backhoe and loader to be a bit faster. The restriction could be hose diameter, or possibly limited by the pump it comes with. Has anyone messed with theirs? Perhaps found a replacement pump with higher output at the same 2000psi pressure rating? I've done research and so far I've come up with nothing substantial. I did build a test gauge and confirmed my pump output is at perfect pressure, so I've never needed to adjust it.
Any help is appreciated!
