LS xr4150H error code F02 973
   / LS xr4150H error code F02 973 #1
dougiewow
LS xr4150H
This error indicates excess water in the fuel. How do I reset the code after the repair. I replaced the fuel filter, added fuel treatment and filled the tank. Seems to work fine but after 15 minutes the error code comes back on and goes into idle mode. 15 minutes all is good again and so on.
   / LS xr4150H error code F02 973 #2
You may want to post this in the LS-specific forum, as there will be more people there who could help. I have not had any errors on mine that did not clear themselves after the issue was fixed, but unless you have a code scanner that will work with the computer, it may be a call to the dealer for direction.
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
2019 INTERNATIONAL MV 16' BOX TRUCK (A54607)
2019 INTERNATIONAL...
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A53473)
Texas Post Driver...
2008 Ford Focus Sedan (A53424)
2008 Ford Focus...
2017 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A52705)
2017 CATERPILLAR...
