Ls4140HC annoying noise from dashboard
   / Ls4140HC annoying noise from dashboard #1
cottonbill
xr4140
My ls4140 had a rattling (buzzing sound) at different engine revs' that was very annoying. The fix was very easy but not very obvious at first. The sound was like lead shot vibrating on a glass plate. My first guess was the throttle linkage inside the dash and this was only partially the fault. My next attempt revealed the full and low throttle stops which are an upper and lower limit pins that the throttle lever contacts at the extremes. The fix was to smear a bit of RTV over the ends of each pin.It is necessary to only remove the RH side access panel and reach up to where the throttle lever pivots on it's mount.
2013 John Deere 544K Articulated Wheel Loader (A50322)
2013 John Deere...
2017 Bomag BW90 AD-5 Vibratory Articulating Tandem Smooth Drum Roller (A50322)
2017 Bomag BW90...
Kubota SVL95-2 High Flow Cab Skid Steer (A51039)
Kubota SVL95-2...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
2011 L3 GENERATOR SET (A51222)
2011 L3 GENERATOR...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A51039)
2024 BCL...
