LT 1050 Spindles
   / LT 1050 Spindles #1
esbwn
Bronze Member
Payne Oklahoma!
Mahindra 2816
Has anyone else had trouble with the deck spindles on you LT 1000 series? I had to replace one last season, at my cost of course, because the bolt warped on me and would not let the spindle spin. I at first thought I could have hit something, as the dealer had proposed. I am now getting the same humming noise coming from the deck that I did before it went out the first time. I know I have not hit anything this season. Any ideas? Is this a trouble point for my beloved mower? Other then that little problem, I have no other complaints. *After I figured out how to disable the no mow in reverse over ride*
   / LT 1050 Spindles
   / LT 1050 Spindles #3
I wonder if the deck shell is flexing causing the blade spindle housings to warp?!? Do you let the deck ride fully on the ground when you mow? That is very rough on this style deck.
Joel
   / LT 1050 Spindles #4
Joel
   / LT 1050 Spindles #5
My 50" deck does not mow well; it leaves a "line of grass; has done it since new. No problems with spindles so far.
   / LT 1050 Spindles #6
   / LT 1050 Spindles
yes i do mow on the lowest setting, but i thought rollers would not allow the deck to flex much? also, im thinking about going with a "gator" blade. anyone had any expereince? where is the best place to get them?
   / LT 1050 Spindles
   / LT 1050 Spindles #9
I also am thinking of gator blades
2021 Case Trident 5550 Spreader (A52128)
2021 Case Trident...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
ALL AMERICAN BIG J SERIES (A51243)
ALL AMERICAN BIG J...
2025 JMR 40in Single Cylinder Hydraulic Grapple Bucket Skid Steer Attachment (A50322)
2025 JMR 40in...
2018 LAYMOR SM450-ST SWEEPER (A51242)
2018 LAYMOR...
