hslogger
Platinum Member
I recently acquired a rather derelict LX172 as a barn find. Hood of course toast. Couple tires flat. Bagger assembly intact. I drug it out and loaded it onto a trailer and hauled it home.
With some standard boy scout procedure I got the Kawasaki 14hp to run like a clock. New air filters, plug, oil filter and plug, gas filter, and clean non ethanol gas. Voila!
Wheels are rusted firm on the rear axle and so far all heating and Blaster to no avail. Front wheels are rusted on the spindles ditto.
I removed the deck and one spindle totally wallowed out. Housings are ugly. Blades rusted to death but with no sharpening wear on them at all. Frozen blade nuts. I ground the heads off and dropped the blades and will wire wheel the tension washers and the blades and sharpen them. I am going to replace both spindle assemblies and probably the idler and of course the belts. Other than the bottom rust it looks pretty good to me. I am not sure,looking at diagrams about plastic bushings that might be part of the deck assembly.
So, I am no stranger to JD mowers of merit, have a primo LX 178 and I took this project on for kicks. So far I don't think I am nutzo but won't know till I get the tire repaired and try to drive it, check out the transaxle and gears. My gut says this thing is gonna be ok... I hope. If the mechanics prove favorable, down the road I will spring for new hood, but not until I figure if this thing is going to be resurected in full.
So I am looking at a lot of deck parts, probably a new seat cushion for right now. In years past I would just go to the JD dealer and may well again, but I am tempted by some of these internet parts.
What do ya'll think about ordering brandX or OEM JD stuff on line and who do you recommend or NOT recommend. Thanks to you all.
