LX280 failed PTO
   / LX280 failed PTO #1
Mike Stack
Lx280
I have a John Deere 05 LX280 and the pto quit. I purchased and checked the new pto switch, good switch. I next checked the pto clutch and it checked out. I then checked the ohms from the wire that runs from the pto switch to the clutch, all good yet I still doesn’t work. I run out of ideas and am reaching out for another opinion. Thanks
   / LX280 failed PTO #2
Not that I know anything about an LX280 but just how did you check the PTO clutch and determine it "checked out"?
Just assuming here, this a hydraulic PTO clutch pack. USUALLY that would have a test port somewhere so you can test the pressure to the clutch when it's applied.
   / LX280 failed PTO
I checked the ohms which showed 3.8 and they are supposed to be between 2.0 and 4.0. I also took the battery out and connected it directly to the electric clutch and it clicked on and off. I normally bypass the seat switch, but I reconnected that as well. Fuses were good.
   / LX280 failed PTO #4
I guess you presume everyone should know what an LX280 is... I don't. Be more specific like what brand for instance.
   / LX280 failed PTO
I’m sorry, it’s a John Deere LX280.
   / LX280 failed PTO #6
Maybe the wiring from the pto switch to the clutch has too much resistance to get enough volts to activate the clutch.
Put your meter on the clutch with the switch activated and see what the voltage is.
   / LX280 failed PTO #7
I looked at the specs and I see it's a lawn tractor with an electric pto. I'd say you are having issues with the electro-magnetic clutch itself. Probably a broken wire or a failed electro magnet inside the clutch itself and you don't want to know what a new one costs either. Lets just say, not a cheap date.
   / LX280 failed PTO #8
If it's similar to the one I had on my Cub 60" tank, it's not adjustable and the electro magnet is sealed inside and not user serviceable. Good luck. I bought one aftermarket and it was still over 300 bucks. I bet JD wants at least 500 for it.
   / LX280 failed PTO
Thanks for your help, I’ll have a look at those as well. It did click though when I hooked up the pto clutch to a battery directly.
   / LX280 failed PTO #10
There may be a relay in the circuit, I had 4 fail in my JD 4300
6Yd Dumpster (A44571)
1998 FORD L8000 TRI AXLE DUMP TRUCK (A43004)
1998 FORD L8000...
2006 CHIEF 46' CONTAINER CHASSIS (A43004)
2006 CHIEF 46'...
New/Unused 10ft x 20ft Single Garage Metal Shed (A44391)
New/Unused 10ft x...
2015 Ford F-150 Ext. Cab Pickup Truck (A44572)
2015 Ford F-150...
2011 Ford Expedition XLT SUV (A44572)
2011 Ford...
