lyman 1a peep sight
   / lyman 1a peep sight #1
haroldy
near peterborough,ontario
kioti ck30,,front mount snowblower
I have a problem with peepsight on savage 99
when folded to uprite position detente,on sight is not verticle
can this be adjusted
   / lyman 1a peep sight #2
Not quite sure I understand the problem. Is it that upon folding up the sight, the upright is not 90ー to the barrel (completely vertical)? Or is it that the sight is off horizontally when folded up? I would first suggest taking a good look at the sight and make certain it is not bent or broken.
you are right in the first statement
no the sight is not bent or damaged
it can be locked in the proper alignment but i feel this shouldent be necessary
if it went to the detente position
thanks for the reply
i took to 2 gun shops but they didnt know how to fix
   / lyman 1a peep sight #4
As I'm not real familiar with that sight I'm still just guessing, but I assume you would want to prevent it from locking in the upright position to prevent damaging it while carrying afield or other? I would note under the circumstances, it having something to lock it in position makes certain it is completely upright. Otherwise, it not being quite upright would change the point-of-impact (once sighted in) exponentially as distance to the target increases.
   / lyman 1a peep sight #5
Can you post a picture of it up in detent position.
How far off vertical is it?
Is it marked "SA"?
   / lyman 1a peep sight #6
Is this sight on the tang? If it is, there is a spring in the barrel
of the sight, The have been known to break
2022 ELITE 102" X 40' GOOSENECK TRAILER (A50459)
2022 ELITE 102" X...
2014 MAGNUM PRODUCTS LIGHT TOWER (A50854)
2014 MAGNUM...
72In FEL HD Round Back Bucket (A51039)
72In FEL HD Round...
2021 ALLMAND BROS, INC. NIGHT LITE TOWER (A50854)
2021 ALLMAND BROS...
2008 FREIGHTLINER B2 BUS CHASSIS (A51222)
2008 FREIGHTLINER...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
