M 7040 tires
   / M 7040 tires #1
abbjulian
Mexico
Hey guys Front and rear tires (9.5-24, 16.9-30) can be changed to (14-17.5R4, 16.9-30 or 16.9-28)?
thanks
   / M 7040 tires #2
1) why change size from stock? 2) can't directly answer on your size question,but are you going to an industrial or turf size? I'm told the ratio between ft and rear are critical to the 4WD system, arbitrary differences can mess up u joints or worse....why change? Best to go through Kubota central on that question, may mess up warranty, etc. bigger is better may not apply here bb
   / M 7040 tires #3
I would go with whatever sizes are the std size from Kubota.
   / M 7040 tires #4
You might find tht ou will have some driveline difficulty with mixing the tread style.
   / M 7040 tires
thanks
i need m7040 in low profile, narrow is not functional. ft ind rear Ag, I will ask if the indication of the subject exists.
   / M 7040 tires #6
There is a low profile M model available, the tire sizes should be on Kubota site.
2002 International 9200i Truck (A55218)
2002 International...
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A52377)
2021 Freightliner...
2005 INGERSOLL RAND SD-70D TF SMOOTH DRUM ROLLER (A52706)
2005 INGERSOLL...
2017 Nissan Frontier Pickup Truck (A53422)
2017 Nissan...
SKID STEER HYDRAULIC TREE PULLER (A53843)
SKID STEER...
