M/F 135 oil pressure ?
   / M/F 135 oil pressure ? #1
double hunter
Ford 1715
Just bought a M/F 135, 4 cyl gas, (1964) nice tractor and runs great, the oil pressure runs a 20 psi, a buddy of mine was looking at it and said he thought that was low, my question is what should the oil pressure run
   / M/F 135 oil pressure ? #2
Is that the oil preasure at max RPM or idle? Could be the gauge, could be trouble. I had a low oil pressure issue with my Diesel MF135, almost junked the tractor before I discovered that Diesel was leaking into the block via the lift pump. Fixed the pump, changed the oil and all okay now,. IE right after oil change pressure good and as the weeks go by it got lower and lower. Doubt it would be the same with a Gas tractor, have you changed the engine oil yet?
2020 KUBOTA SSV75 WHEELED SKID STEER (A51242)
2020 KUBOTA SSV75...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
Brown 417 7ft Rotary Cutter (A50490)
Brown 417 7ft...
2007 STERLING TRUCK ASPHALT DISTRIBUTOR (A50854)
2007 STERLING...
PALLET OF TARPS, UMBRELLAS, AND PORTABLE SHADES (A50854)
PALLET OF TARPS...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
