M4900 Kubota locked in Rev???
   / M4900 Kubota locked in Rev??? #1
Tx Jim
New Member
Coyote Flats,Tx
JD 4255/Kubota M7040 HDC
I have a M4900 cab tractor with syncro-shuttle that I put in reverse and now it won't come out of rev. If the 2 speed selector and the 4 speed selector are both in neutral and I put shuttle in fwd it loads engine. It will back up in all gears. I checked shuttle shift linkage and it all appears in working order to the clutch housing. I've owned tractor for 4 yrs and it has 1452 hrs on speed/hr meter. I'm stumped. Thanks for any ideas,Jim
   / M4900 Kubota locked in Rev??? #5
Hope this will help. My L245DT also would hang up in rev. If you have a stick with gears like i do check the shifting forks on the top where the shifter moves. Mine was worn and the trans. was not synchronized .I was able to repair by silver soldering and filing the worn areas. If you need more infor, let me know.
Bill
New/Unused Pallet of 5 Binder and 10 Chains (A44391)
New/Unused Pallet...
New/Unused Pallet Forks (A44391)
(1) HD 12ft 6in Panel (A44391)
(1) HD 12ft 6in...
2016 Ford F-150 Pickup Truck, VIN # 1FTEX1CG6GKF21612 (A44391)
2016 Ford F-150...
2018 Bomag BMP 8500 Trench Compactor (A44391)
2018 Bomag BMP...
2021 Ford Explorer AWD SUV (A44572)
2021 Ford Explorer...
