podzie
Bronze Member
Does anyone have a manual they could share showing the hydraulic hose routing for a LA1002?
While disconnecting my shredder yesterday to hook up a PHD, I noticed a lot of hydraulic fluid coming out from the sleeve that contains the hyraulic lines from the belly and rear of the tractor that route up to the loader control box.
When taking the hoses off to take them up to a local NAPA, they fell to the ground before I indexed the location.
I wasn't concerned because I thought that I had seen that the upper goes to the upper port, the lower goes to the lower port.
BUT, when I replaced the lines, now the 3 ph won't raise unless I go to the FEL joystick and hit the roll back position. THEN, immediately the 3 ph raises.
So do I have an air lock or a routing problem?
BTW, no fence posts in the ground yesterday!!
