M8560HD12
   / M8560HD12 #1
M8560HD12 TAMMARC FARM
Bronze Member
Hamilton, OH
TS6.110 4WD Cab, WM75 FEL ROPS
Looking to purchase M8560 for 38ac horse farm just for haying/plowing...etc have a NH320 Baler w/ Kicker, 4-Bottom IH Plow and 15FT Cullimulcher - just wondering if anyone had thoughts on 76PTO HP being good enough - i currently use a Oliver 1755 Diesel for this type of work
Also, I am looking at the unit w/ the bucket and 1 Rear Remote - is that enough to run a Hay Bine [NH479] and the NH320 Baler that has hydraulics on kicker, or, would I need a 2nd Float Remote
I am just a weekend Warrior, so my knowledge on what I need on a new tractor is severely limeted
   / M8560HD12 #2
We have an M8540, but know nothing about haying; might check here; good luck.
Haying
   / M8560HD12 #3
Greetings and welcome to TBN.
Sent from my iPad iOS 6.01 - TNB v1.6
   / M8560HD12 #4
:welcome:
   / M8560HD12 #6
Welcome I own an M8540 its a great tractor I don't produce hay. I checked the manual they claim the largest plow you can run up to a 4 bottom plow with 16" bottoms. If you have soft soil or well worked i don't think you will have a problem. I ran a 2 bottom plow with 16" bottoms 10 -12" deep in clay and rocks that had not been turned in the last 25-30 years. It worked the tractor good but i had plenty of power to run 3rd gear at about 3.5 mph. I think the 12 speed would have helped to have a gear in between my 3rd and 4th. I don't think i would not have been able to pull a 3 bottom plow. When we turned the soil in the fall and it pulled the plow in 4th with no problems. The baler should not be a problem, the cultimulcher might be your biggest problem the M9960 might be better suited in terms of power i think they usually call for at least 6 hp/ ft. another question would be weight you would probably need the all the ballast you could get including cast centers and tire ballast.
   / M8560HD12
Dave, thank you for the details! I do have a 3-Bottom, but I have also thought about jumping to the M9960 so I can pull the 4-Bottom - The weight/balance is also a concern so i am going to talk to dealer about weights/balance etc - i was hoping that with the front loader i would be set up front but possible rear wheel weights for balance is needed - will be seeing him tomorrow - I greatly appreciate the feedback as just owning 1969 Oliver 1755 and 1972 IH574, I am learning on the fly with all these specs/options
   / M8560HD12
Thanks TripleR - it was helpful - this website is unreal - I have been flying by seat of my pants for years now and have just been lucky - hoping to learn a lot on this site!
   / M8560HD12 #9
No problem with the loader on the front i think you'll be set for weight on the front axle. But i would definitely get the cast centers and liquid ballast. If thats not enough you could always add wheel weights later. I think my 8540 would pull the 4 bottom now that my soil has been broken up. But you probably still need the hp for the cultimultcher. How well does the Oliver handle it?
Dave
   / M8560HD12
Dave
I did have the Cast Centers quoted, but I may have to have them fill tires [I assume that's what you mean by Liquid ballast?] The Oliver 1755 [85HP Diesel] pulls that cullimucher quite easily, that's why I was leaning towards the M8560 - I still may just jump to M9960 to cover my behind
CLASS ROLLANT 160 HAY BALER (A51243)
CLASS ROLLANT 160...
2011 Jeep Grand Cherokee Laredo 4WD SUV (A50324)
2011 Jeep Grand...
UNUSED JCT DUSTLESS BLASTER (A51244)
UNUSED JCT...
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A52128)
2022 MAXXD BD14...
International 4700 Vibra Tiller (A51039)
International 4700...
