m9540 Kubota
   / m9540 Kubota #1
Longr
2011 m9540 kubota
Need to flush cooling system on my m9540. Want to flush block and radiator. Am not sure where to drain the block. Both radiator hoses attach to the block too high to assist in draining the block. Appreciate any assistance.
   / m9540 Kubota #2
Can you drain it out of the lower hose? If you have a cab is the heater return hose low enough? What does your WSM say?
   / m9540 Kubota #3
Do you have the operator's manual? My Kubota manual shows how to drain coolant from the rad and block. On the M7040SU there is a bolt near the oil fill plug that you unscrew and the coolant drains out.
Mi-T-M AS6-HE15-120M 175 PSI Air Compressor (A50322)
Mi-T-M...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
2016 Toro Pro Force Towable Blower (A50324)
2016 Toro Pro...
2018 Ford F-550 Truck Altec AT40G 40FT Insulated Bucket Truck (A50323)
2018 Ford F-550...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
2019 John Deere TX Gator Utility Cart (A50322)
2019 John Deere TX...
