Mowing M9540 Pto vibrates
   / M9540 Pto vibrates #1
Mike Reid
M5400, M6800, M9540
I hooked my 6’ brush hog up to my M9540 and it basically shakes and vibrates my tractor so bad it feels like the windows are going to rattle out. If I hook the same mower up to my M6800 it mows and operates smoothly, anyone have any thoughts?
Typically my M9540 is a dedicated to my 15’ batwing but I was noticing some vibrations and I knew my right wing driveline was in bad shape so I hooked up my 6’ mower and the vibration was unreal!! I put a new drive line, blades and stump jumper on the 6’ mower and the vibration was less but still very noticeable! Any help would be greatly appreciated!
   / M9540 Pto vibrates #2
Intriguing to say the least. Being smooth on the M6800 vindicates the mower. Logically it can't be the mower nor the driveshaft to the mower. The fact that you had vibration using the batwing that led to this investigation in the first place certainly points to the M9540 and only the M9540.
You say the 'right wing driveline was in bad shape' -- Are you meaning 'batwing driveline was in bad shape' or just the right side subset?
I do not own a 9540 so cannot speak from direct experience but I am an old retired engineer with a lot of vibration analysis background and many years tinkering with tractors.
First thought is that the driveline issues with the batwing got bad enough that they damaged the bearings for your 9540 PTO shaft. I assume you have grabbed the PTO shaft and tried shaking it laterally, up/down etc. Does it feel loose? In disconnected status do the bearings feel OK ? Roll easily with no lumps and catches? If you run the PTO in a no-load mode (e.g. with no implement connected but running the PTO at rated rpm) does it rattle or make excessive noise ? Compared to the M6800?
Second thought: Is a high rpm PTO invloved here like 1000 rpm? If so go back to 640 rpm and check things.
That's about all I can suggest
   / M9540 Pto vibrates #4
Check the u joints on the drive shaft to the mower. Out of phase?
   / M9540 Pto vibrates #5
   / M9540 Pto vibrates #6
Can't be. He already tested it on another tractor with smooth results. Any power train phasing issue (which only exists due to faulty assembly of U-joints connected by a drive shaft) moves with the implement.
   / M9540 Pto vibrates #7
Are both tractors running the same pto rpm?
   / M9540 Pto vibrates #9
On the 9540 it's not possible to mistake the PTO speed 540 versus 1000.
The shaft is swapped to change speed. Six spline versus twenty spline.
I'm with Rick in regards to handling the shaft looking for bearing failure or bent shaft.
   / M9540 Pto vibrates #10
It is possible then that the different gears/shafts (internally) could also have an issue, not just the swappable pto shaft.
CAT Skid Steer Grapple (A51573)
CAT Skid Steer...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
2014 Ford F-150 Ext. Cab Pickup Truck (A50323)
2014 Ford F-150...
LOAD OUT INFORMATION (A53084)
LOAD OUT...
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
