Mahindra 1533 no fuel to injectors
   / Mahindra 1533 no fuel to injectors #1
WncLee
Mahindra 1533
I have a Mahindra 1533 that's computer controlled that I'm getting fuel to the air bleed screw on the injection pump but not to the injectors when cranking it over. I pulled the fuel shutoff solenoid & tested it, can hear & feel it actuate, can't see the plunger on it because of a screen on the end of it, with key on & also cranking it's only getting 8.8volts & just hums. It has a new fuel filter in it,turns over fine just doesn't start, tried bleeding the injector lines when I found out that nothing is coming out. I checked codes & had one for low pressure,cleared it & nothing has popped back up. Any ideas of what to check?
   / Mahindra 1533 no fuel to injectors #2
Take the solenoid out and try to bleed the air out..
Once u get fuel spurting out of the loosened inj lines, tighten them up & try to start it..
JOHN DEERE 333G SKID STEER (A52705)
JOHN DEERE 333G...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A54607)
2019 KENWORTH T680...
2018 Skyjack SJIII4740 40ft Scissor Lift (A52377)
2018 Skyjack...
377789 (A51573)
377789 (A51573)
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
