Mahindra 2555 PTO not turning
   / Mahindra 2555 PTO not turning #1
East TX
Mahindra 2555 HST
Was out doing some stump grinding and piling some brush this morning. I finished a couple stumps and turned off the PTO (woodland mills PTO stump grinder). Did some work with the grapple cleaning up some downed brush. When I went to start grinding another stump, the PTO wouldnt engage. The pushbutton light is on, but no sound heard and no spinning. The only other thing, which i wouldnt think was related, was when the PTO didnt engage, I looked at the dash and saw the 'water in fuel filter' light on. Shut the tractor down. Dumped the filter and replaced. No more warning light, but PTO wasnt working. Thoughts? I was hot, sweaty, tired, and had a wife waiting to leave so didnt do much trouble shooting. Is there a fuse for it? Something else to look for when i go back out? Unfortunately, my tractor is about 2 hrs from my home on our property. Its an HST if that matters and i did check the hyd fluid dipstick and looked good
   / Mahindra 2555 PTO not turning #2
Might take the ground cable off the battery for a few minutes ,I guess it's possible the computer hasn't detected any change.
   / Mahindra 2555 PTO not turning #3
I have a Mahindra 4510. I think it has 2 and perhaps 3 areas that activate/deactivate the PTO. Could one of those have gotten bumped/disconnected. I remember a time when I would blow fuses with some regularity. Just carried spares. Unsure what caused that but I thought it was a PTO issue. Just can't remember for sure nor the cure.
   / Mahindra 2555 PTO not turning #4
You indicate moving some brush. You also indicate it is a push button PTO. In other words it is an electric clutch for the PTO.
Exposed wiring and brush are no friendly to one another. I would start by crawling under the tractor with a good light snd look for electrical connections that have been pulled apart and for wires that have been pulled out of connectors. Make any needed repairs to wiring. Put exposed wiring in a loom then secure the loom so that it is as difficult for brush to interfere with the wiring as humanly possible. Unfortunately, brush will grab onto anything loose and then not let go causing troubles.
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
2015 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2015 Ford F-250...
2008 Ford F-350 4x4 Crew Cab Pickup Truck (A50323)
2008 Ford F-350...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2016 Ford F-450 Crew Cab Kanpheide Service Truck (A49461)
2016 Ford F-450...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
