Mahindra 3510 HST Pedal Linkage Repair
   / Mahindra 3510 HST Pedal Linkage Repair #1
bruhhindra
2004 Mahindra 3510 HST
I have an older 3510 HST, around 2004 era. It has quite a few issues, but the pedals recently stopped working completely (they had been stiff and messed up for a while, wasn't sure what was wrong). Turns out the part Mahindra refers to as LH Elbow had busted underneath it. It links the rod from the pedals to the block that operates the HST. The bolt part of the elbow had busted off so I was able to remove it and unscrew it from the rod with little issue. I ordered a new one, $29, and it got here. Got under there and of course now I can't get it into the hole because of the cast iron shroud around all of it. Look at the schematic in the service manual (yes, I have one), and looks like that block it goes into is removable with one big bolt. Break that sucker off finally with a breaker bar and a wrench to hold, and bolt comes out! Go to pull off the block and .... it impacts against the d*** cast shroud! There's a lip RIGHT in the way of removing it. Seriously considering grinding that lip off the inner cast shroud but the tractor is in an awkward position out in the snow, can't jack it up at all, so space under is pretty tight and I don't have any small grinders to shove up in there. Any suggestions would be VERY welcome! The dealer is 80 miles away and I'm sure they'd probably charge me an arm and a leg.
Well I ordered a burr bit for a die grinder to take that cast lip off of the inside of the housing where I need it to be gone. Wish me luck!
Burr bit worked to gouge enough out to slide the elbow in! I now have everything working!
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51691)
2015 Toro Multi...
2015 KENWORTH T680 TANDEM AXLE SLEEPER (A52577)
2015 KENWORTH T680...
2005 Reinke 48ft Stepdeck Trailer (A51572)
2005 Reinke 48ft...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
2008 Ford F-450 Crew Cab Service Truck (A52377)
2008 Ford F-450...
