Oil & Fuel Mahindra 3525 gear box
   / Mahindra 3525 gear box #1
Hector Reyna
Mahindra 3525
I am having trouble locating where to refill the 90 weight on the PTO gear box. Anyone have any help me out.
   / Mahindra 3525 gear box #2
I am not positive but the PTO is probably not supposed to be filled with 90 weight. I think it is to be filled with transmission/hydraulic oil which is for sure not just "plain ole 90weight". Any how, look to the right front of the gear shift lever, the dip stick / fill plug should be there. It should be very similar if not the same as my 4025. Be careful what you pour in, it could make you pour in a bunch of cash behind it.
   / Mahindra 3525 gear box #3
The manual will tell you the correct weight. If I can find it I will post it here later.
   / Mahindra 3525 gear box #4
My 2006 manual says API G1-4 EP Gear Lub. But you may want to check with the dealer. If you have found out differantly could you post it so I will know. Thanks
   / Mahindra 3525 gear box #5
slight correction from above post, sorry. The correct oil is
API GL-4 EP Gear Oil, facory filled with 90W. The book says do not use GL-5
1988 Butler Equipment Trailer (A50515)
1988 Butler...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2012 Ram 4500 Chassis Vesralift Bucket Truck (A50323)
2012 Ram 4500...
kyle kelso auctioneer (A50515)
kyle kelso...
2015 Revere Shasta 27DB 5th Wheel Travel Trailer (A51694)
2015 Revere Shasta...
