Mahindra 3616 HST Hydrostatic Issue
   / Mahindra 3616 HST Hydrostatic Issue #1
awill99
Bronze Member
15 acres Celeste
Mahindra 6500 4WD with Skid Steer FEL.Mahindra 3616 HST with Skidsteer, Vermeer RT200 Trencher
Have a new 3616 with just 2 hours on it.In MID and HI range when I steer right or left the ground speed goes down.The more I turn the more the speed falls.Going in a straight line up a grade the speed also falls.In all cases the engine is not strained-it is not changing speed.Is there an adjustment for Hydrostatic pressure?
   / Mahindra 3616 HST Hydrostatic Issue #2
Wish i could help, but I only have a couple hours on my 3616. Does it do the same thing in low range? Have you contacted the dealer?
   / Mahindra 3616 HST Hydrostatic Issue #3
It will do that a little if you're in 4wd. You're dragging one wheel when you turn a corner.
I suspect you're not familiar with how an HST works. Pressing the pedal down puts it in a higher 'gear'. When climbing a hill you need to let off of the pedal to put it into a lower 'gear'. The hst has an infinite number of 'gears' ..every position of the pedal is a different 'gear'.
2000 Mack CH612 Day Cab Wet Kit Truck Tractor (A44571)
2000 Mack CH612...
2014 Ford Taurus Sedan (A44572)
2014 Ford Taurus...
40' 6 Door Container (A45336)
40' 6 Door...
2022 Down2Earth 82in x 34ft Two-Car Hauler (A46877)
2022 Down2Earth...
2022 CASE CX130D HYDRAULIC EXCAVATOR (A43004)
2022 CASE CX130D...
2012 Ford Explorer SUV (A44572)
2012 Ford Explorer...
