Mahindra engine
   / Mahindra engine #1
cdover73
Greensburg, Louisiana
2006 Mahindra 4530
I have a 4530 and I have to ask. If Mahindra makes the engines for these tractors, why do they look and sound so much like a Perkins?
   / Mahindra engine #2
I know I read it somewhere and asked the local dealer a while back when I went to look at the 4530. He said the engine was a Perkins/Shibaura 3 cylinder, but I could never find out exactly which engine it was. It would make sense since I believe a Mahindra assembly plant and a Perkins plant are in Georgia, but that may just be a coincidence.
I believe the smaller Mahindras use the Daedong engine.
   / Mahindra engine #3
Gentlemen, the '00 series engines (and I assume the 4530 as well as the 7520, etc) are completely built by Mahindra in India. The parent engine (00 series 3 and 4 cyl) were specifically designed by AVL in Austria for Mahindra. AVL has been building diesels for quite some time (I'm thinkin' pre WWII). It is entirely possible that Perkins (also Euro) copied some of the AVL designs way back when.....I'm just hoping that the Mahindra engines are as good as their designs.
   / Mahindra engine #4
Many of the smaller Mahindras (specifically the 15 series; 2015, 2615, 2815, 3015, 3215, etc.) use Mitsubishi engines.
BR
   / Mahindra engine #6
Well thanks so much for this info I have a 2021 Mahindra 2638 tractor. The plate that is on tractor and the stamped in block numbers are below,
Plate on tractor
Agriculture tractor 2638NH
4 cycle diesel 37.4 HP/2400RPM
serial number=38HRR09621
TONG YANG MOOLSAN CO,LTD
The information stamped into the engine block are:
EB-01-18-2021
NMKK JDE0244
Would you know who makes this engine please its a 4 cylinder no turbo and its 37.4 HP. Please give me anything you may know i have looked quite a bit,Thanks Mike Buck
   / Mahindra engine #7
Tong Yang Moolsan (TYM) built tractor, just like my 2001 4110. Daedong engine - mine is an A200, 41 hp. Mine has well over 3200 hours on it and doesn't ever fail to start year 'round and doesn't use/leak a drop of oil.
   / Mahindra engine #8
Plate on tractor
EB-01-18-2021
NMKK JDE0244
It is my understanding that the 2538/2638 engines are in-house products:
Built in India and shipped to South Korea to be installed on the tractors there.
   / Mahindra engine #9
I just checked if Daedong made my exact HP/Cyl and here is what came back"
Yes, Daedong makes a 4-cylinder, 37.4 horsepower diesel engine:
  • Daedong diesel engines
    Daedong Industrial Co., Ltd. produces a range of diesel engines from 20–60 horsepower, including a 4-cylinder, 37.4 horsepower engine.
   / Mahindra engine #10
The info from tractor data .com says thet is a mahandra built engine with 166.7 ci do you have regin function on the engine ?
NEW Wolverine Skid Steer Trencher (A48289)
NEW Wolverine Skid...
1979 Trail 40 ft Hopper Bottom Grain Trailer - Dual Grain Doors and Leaf Spring Suspension (A48561)
1979 Trail 40 ft...
2019 Ford F350 DRW XL CC Crew Cab 4x4 Service Truck (A45336)
2019 Ford F350 DRW...
Bad Boy Rebel Zero Turn Mower (A47484)
Bad Boy Rebel Zero...
2019 John Deere HPX615E 4x4 Utility Cart (A46684)
2019 John Deere...
1996 Monon 45X96 Dry Van Trailer (A48561)
1996 Monon 45X96...
