Mahindra wheels on a Ford?
   / Mahindra wheels on a Ford? #1
jd4044m
John Deere 4044m Ford 7610 John Deere 420
I'm looking for some 34" wheels for the 7610 Ford and I've found some off of a Mahindra, it says the lugs are 8" apart with a 6" center hole. I had someone measure the 7610 and the 8" lugs are the same but the center hole only measures around 5 1/2 ". Will they work ?
   / Mahindra wheels on a Ford? #2
The centering hole should carry the load. Don't let painted surfaces interfere with precise measurement.
Have your machine shop guy lathe-turn some 5.5" ID 6" OD rings accordingly to make up the diff.
Your lugs should then only see rotational loads as intended.
btw, If your 7610 is 4WD you'd want to match tire OD to what you take off.
Ok yeah I hadn't thought of that. And no it's 2wd
The lugs nuts on the Ford are acorn style (tapered) so they should take the weight off of the center hub anyways right? Or no?
2019 UTILITY 53X102 REEFER TRAILER (A52576)
2019 UTILITY...
2006 KOMATSU  D41P-6  CRAWLER TRACTOR (A52576)
2006 KOMATSU...
2020 John Deere 8R 410 MFWD Tractor (A53342)
2020 John Deere 8R...
2011 INTERNATIONAL MA035 ROUSTABOUT TRUCK (A52472)
2011 INTERNATIONAL...
SORKO MC19-10 LOT NUMBER 149 (A53084)
SORKO MC19-10 LOT...
2012 LEDWELL & SONS ENTERPRISES, INC. 48 HYDRAULIC TAIL DROP DECK TRAILER (A52472)
2012 LEDWELL &...
