Main hydraulic pump leakage
   / Main hydraulic pump leakage #1
RHughes
Autauga County, AL
New Holland TN65
I'm coming up to the 50hr mark on my new TN65.
I was bush hogging the other day and noticed something dripping, just a little, on the steering hydraulics. A quick check found that there was there was a small seep at the fitting on top of the main hydraulic pump. This doesn't seem to cause any problem with the hydraulics operation and fluid level is still normal. The main thing it does is act as an "enhanced" dust and trash catcher.
The tractor is under warranty so the dealer will come out and fix it, no problem. He also said that they had several of the TN series tractors show that same problem after a bit of breaking in.
I was just wondering if any other owners here had seen the same thing.
Regards,
   / Main hydraulic pump leakage #2
I've seen it on TN's and TL's. Probably a pinched o-ring, assembly error. The thick chassis paint kept it bottled up for a while.
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
3pt 6' Box Blade (A50121)
3pt 6' Box Blade...
2018 Allmand Light Tower (RUNS AND WORKS) (A50774)
2018 Allmand Light...
2012 CATERPILLAR 279C2 SKID STEER (A51246)
2012 CATERPILLAR...
LOAD OUT AND SHIPPING (A51573)
LOAD OUT AND...
MARTIN - SET OF 12 COULTER MOUNT MARTIN ROW CLEANERS (A52748)
MARTIN - SET OF 12...
