Marking lines to dig an area
   / Marking lines to dig an area #1
RayCo
Veteran Member
Chester County, PA
Kubota BX24, Case 580 Super L
I'm wondering what people use to mark the areas that you need to dig out with a backhoe. I need to dig out an 11' square area about 12" deep, and what I'd typically do is paint lines on the ground to do something like this. But, inevitably, the lines get covered or obscured in some other way by the time I'd actually get to finishing. This usually didn't ever matter, because estimating where they were was always fine. But, in this particular task, I want to be a accurate as possible when I'm digging. I've also used string before, but that winds up getting in the way and getting ripped out.
Perhaps the answer is to use the distant marker method, where you put two stakes in the same line as the one you're digging on, but at a distance away from where you're digging and from each other, and eyeball up their alignment to keep myself straight.
   / Marking lines to dig an area #2
I use paint and drive wooden atkes at the 4 corners (if its a square). I place the stakes just outside of where the digging needs to be so I dont loose my marker. I make them the same distance from the edge all the way around so they dont fall in when I dig.
   / Marking lines to dig an area #3
I use the offset lines for out bx's 2' just mises the wheel if you kep a line on stales run your wheel down the line.
I also put lime on the line were Ii want trench to go alot cheaper than spray paint
tom
   / Marking lines to dig an area #4
The wife just stands there and points:D
   / Marking lines to dig an area #6
I will sometimes drive in stakes and run some colored string so I stay inside the box or whatever the design is. I'll spray paint the general line and then use the string for the fine tune digging.
   / Marking lines to dig an area #7
Do your perimeter with a flat shovel.
I don't know how to use a shovel anymore. ;)
   / Marking lines to dig an area #9
I usually just use a series of sticks.. If it is critical to not dig beyond the intended area I cut it in with machete and remove a line of sod/turf...
   / Marking lines to dig an area #10
Cheap bag of lime.
Toro Z Turn (A50322)
2019 Dodge Journey SUV (A50324)
2019 Dodge Journey...
2021 HITACHI ZAXIS 35U EXCAVATOR (A51242)
2021 HITACHI ZAXIS...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2018 FREIGHTLINER...
Marliss Industries Grain and Soybean Drill - Selling ABSOLUTE NO RESERVE (A52128)
Marliss Industries...
2018 Nissan Versa Sedan (A50324)
2018 Nissan Versa...
