Massey 180 that sat since 1993
   / Massey 180 that sat since 1993 #1
cyclospot
Mayview, MO
180 MF, 756 IH
Hello everyone. I have my Grandpas Massey Ferguson 180 that I finally got around to fixing. It sat outside for a long time. I was bright enough that I kept the exhaust covered and it broke loose easily. Had a valve stuck and bent a pushrod. A little tapping on top of the valve and some good penetrating oil freed it up. The injector pump and injectors, clutch, one brake, a rim, tires, got replaced or rebuilt. Now I am on to the hydraulics and was going to start with the filters. The one I will split the tractor again to get to and the front one behind the grill i think goes to the multi. After that I need a little advice on where and what order to go through them. Any input is welcome. Thanks.
   / Massey 180 that sat since 1993 #2
The power steering will always be better one way than the other due to the design.
Just curious, are the brakes dry disk?
Good luck with the multipower. I can't help you there, I only drove them (135 & 178).
Yes, it is a dry disk brake. I saw a kit somewhere that would make them wet. Pretty expensive if I remember right.
   / Massey 180 that sat since 1993 #4
The wet disc was to expensive for my father (178), and you will be changing most of the back end. There is also a kit to make the dry disc brakes work better, but it is just a bad design. I learned to drive without using the brake as much as possible to make the brakes last. You just use a gear low enough to hold you back on the hills.
   / Massey 180 that sat since 1993 #5
I totally disagree about the steering better one way than another. The 180 has the same type hydrostatic steering like 1080, 1085, and all 1100 series. Early models did have the Saginaw steering hand pump while all later had the Charlyn hand pumps. I believe you are thinking of the 50, 65, 150, 165, 175 that all had mechanical power assist, those could steer poorly either way if the spool valve was not set right..
   / Massey 180 that sat since 1993 #6
Hello dieseltech, you are right, I was thinking of the 175/178. my mistake.Sorry to put you wrong cyclospot.
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A52576)
2013 PETERBILT 386...
ASSET DESCRIPTIONS & CONDITION (A52576)
ASSET DESCRIPTIONS...
20X 8 SHIPPING CONTAINER (A52472)
20X 8 SHIPPING...
2000 FORD E350 CUTAWAY BOX TRUCK (A52577)
2000 FORD E350...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52577)
2013 UTILITY VS2RA...
