Massey 471 vs 573 vs 2660HD
   / Massey 471 vs 573 vs 2660HD #1
sawtooth
Veteran Member
Eden NC
Ford NAA, Ford 2810, Ford 3910-1, Ford 3910-2, Ford 4600SU, Massey 2660 HD, Massey 461, Grasshopper 725D, Grasshopper 900D
I did't get a response my earlier thread so going to try again. What are the differences to these tractors? Should I be scared of any of them? Trying to decide which way to go.
Thank you,
   / Massey 471 vs 573 vs 2660HD #2
The primary difference between the 471 and 573 is in the hydraulic system and some minor operator improvements. The 2660HD is a fancier version of the 573. Same basic tractor with a better layout, tilt hood and other creature comforts. I wish I could remember what the exact issue issue was on the 471 but I don't - I can tell you on the 471 that you want the "Phase 2" tractors which had a hydraulic system similar to the MF300 Series. Phase 2 cut in at s/n BP02006 on tractors with IPTO and at s/n BP14077 on tractors with Live PTO. Pretty sure there is a service bulletin on it somewhere that helps you identify the difference. I wouldn't be afraid of any of them, but the 2600HD with a mechanical shuttle is the better of the 3 in my opinion.
Ok thank you
2014 TROXELL 130BBL VACUUM TRAILER (A52472)
2014 TROXELL...
198367 (A51243)
198367 (A51243)
2023 EAST TEXAS TRAILER (A52472)
2023 EAST TEXAS...
1972 Baker 30ft Pole S/A Towable Trailer (A51692)
1972 Baker 30ft...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
