massey electric front PTO smoked
   / massey electric front PTO smoked #1
tractorshawn
Canada
Massey Ferguson 1010
Thanks in advance. I have a massey 1010 with a electric front mount pto clutch. Just got done rebuilding the mower deck and noticed that the shaft that drives the electric pto was very sloppy. So I dissesembled and found that the carrier bearing was to large wasnt even holding the shaft. Sourced out a new bearing and reassemble unit.Was workin fine untill the clutch started sending smoke signals.First thought that it was the bearing,I thought a 5 dollar bearing is nothing to lose, worst case i have to replace bearing again. I was wrong i think it is the clutch lining.Is there a better way to hook up my belly mower on this 1010 or am i stuck with the electric clutch that I have to replace? This clutch replacement is very expensive and im not likeing it at all.Grass is still long.
   / massey electric front PTO smoked #2
You might want to check out surpluscenter.com. If you know what the dimensions and/or make of your clutch, you might be able to match up what you have, with what they sell.:D
2007 Ford Expedition EL Limited 4x4 SUV (A53424)
2007 Ford...
2012 Club Car Carryall 1 Utility Cart (A51691)
2012 Club Car...
PAIR OF VACUUM PUMPS (A53843)
PAIR OF VACUUM...
International 574D Tractor (A53117)
International 574D...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
2020 KUBOTA RTV...
