massey ferguson 135 lift problem
   / massey ferguson 135 lift problem #1
bamajon
florence, al
69 massey ferguson 135
my 135 has recently got to where it wont lift while tractor is in neutral. does anyone know what causes this? still works ok in gear.
   / massey ferguson 135 lift problem #2
Need more information. Does the PTO work as it should, or only when the lift works? What transmission version do you have? 6 spd,8 spd, multipower or no. You said lift works when tractor is in gear. Do you mean when tractor is actually moving, or simply shifted into certain gears? Single or dual clutch?
its 69 model
its 69 model
6 speed transmission. not sure about clutc type. pto works fine. when using the tractor the lift works fine but when its just idling in neutral is when it doesnt work
   / massey ferguson 135 lift problem #5
So when operating the tractor at increased rpms it works OK but at idle it doesn't. Could be several things.
You said recently it has lost it's ability to lift the 3 PH, is the tractor stored outdoors uncovered? Are the boots to your shift levers split, that will allow water to contaminate your fluid and turn it a sandy tan colour (like the colour in the case of mine shown in the photo). If this is the problem all you'll need to do is drain / replace the fluid and filter (filter top is located lower / center of photo, adjacent to the PTO engage side cover).
Also, there is a standpipe (upper left of photo) coming out of the pump to the diverter, and the o-rings on either end will deteriorate over time. If they are split then you'll lose pressure. The o-rings can be changed without removing the top cover, you'll need to remove the diverter valve to access the standpipe.
If none of these are the problem, check to make sure your pump is putting out good volume and pressure. If it is and all other possibilities check out, then the lift cylinder itself might need the rings replaced.
Let us know what you find.
2014 Ford F-550 IMT 7500-30 7,500LBS Crane Service Truck (A46683)
2014 Ford F-550...
2020 MITSUBISHI OUTLANDER SPORT (A48992)
2020 MITSUBISHI...
Generac Guardian Generator (A49251)
Generac Guardian...
2014 Chevrolet Cruze Sedan (A46684)
2014 Chevrolet...
2014 UTILITY 53X102 DRY VAN TRAILER (A45678)
2014 UTILITY...
2020 Freightliner M2 106 Terex HRX-55 55ft Bucket Truck (A46683)
2020 Freightliner...
