Massey Ferguson 1522 permissive circuit issue
   / Massey Ferguson 1522 permissive circuit issue #1
Graybeard81242
Poncha Springs, CO
Hello,
I'm having issues with my Massey Ferguson 1522 permissive circuit. The tractor will start and run in neutral, but when shifted into forward or reverse, it dies. I took the cover off around the forward reverse lever and jumped out the indicator switch allowing it to run and drive.
With the jumper in place and before the tractor is moving, engaging the PTO will kill the tractor. After the tractor is moving, the PTO can be engaged normally.
This almost has to be a safety / permissive issue but can not find a wiring diagram or repair manual for the tractor to allow me to trouble shoot the issue. I've tested the relays and fuses under the dash which all seem to be good.
Has anyone seen this problem or have a wiring diagram?
Thanks in advance for your help.
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
FORD 555B BACKHOE (A51406)
FORD 555B BACKHOE...
2017 Ford F-550 4x4 Cab and Chassis Truck (A51692)
2017 Ford F-550...
2015 International DuraStar 4300 Ambulance (A51692)
2015 International...
