Massey Ferguson 165 3pt hitch pops diverter valve.
   / Massey Ferguson 165 3pt hitch pops diverter valve. #1
JRanch
Oklahoma City, OK
Massey Ferguson 165
Hey guys,
Didn't know how to better describe it. I had a stuck spool valve on the hydraulic pump so I decided to remove the lift plate and clean everything out. I replaced the hydraulic filter but everything else looked great. My problem is when I reassembled everything, the 3pt will lift and lower with no problems but when the arms reach the top, the lever on the diverter valve kicks back to neutral. It almost seems that if I held it in position, it would over pressurize and blow a seal or something. When I had it apart, I replaced all orings as well. I need help with this one cause if I leave it the way it is, then I will constantly have to watch it. Its like it is travelling past a stop or something. Are there any adjustments that I can make?
Thanks in advance.
   / Massey Ferguson 165 3pt hitch pops diverter valve. #2
I've had it pop into neutral a few times when using the loader on my 135. If it's popping on the 3 pt., maybe it's going into constant pumping position. Might have to adjust the linkage for the 3 pt. controls. I'm not a real expert on them though.
FRONTIER SA21G LOT NUMBER 145 (A53084)
FRONTIER SA21G LOT...
JACTO ARBUS-1000 LOT NUMBER 71 (A53084)
JACTO ARBUS-1000...
2013 Ford Edge Limited AWD SUV (A51694)
2013 Ford Edge...
2014 PETERBILT 388 AUTO TRANSPORTER (A52576)
2014 PETERBILT 388...
2022 New Holland Powerstar 110 Tractor with Loader (A51573)
2022 New Holland...
2014 CATERPILLAR 279D SKID STEER (A51246)
2014 CATERPILLAR...
