Massey Ferguson 185 / 188 workshop manual?
   / Massey Ferguson 185 / 188 workshop manual? #1
metal manny
Mpumulanga South Africa
Massey Ferguson 188
Greetings fellow tractor enthusiasts
I recently bought a neglected Massey 188 which, I understand, is identical to the 185 other than a longer wheelbase by means of a 6" extension in the gear casing.
I plan to use it on a small farm I've recently bought for my retirement
The tractor runs well and as you'll see, I've prettied it up and repaired all the externally accessible flaws. Shortly I'll need to do some internal work as the hydraulic system is making dutiful noises without any movement at the lift arms. I purchased an owner's manual off e-bay but it lacks detailed overhaul info etc. and have tried sourcing a technical service manual off e-bay and Amazon without success. The only manual for a 185 I can find is a photocopied reproduction from a manual supply company in the UK for what appears to be a king's ransom!
Ok, I know that the references for my model are scarce, but does anyone know where I can access online service data? Does one of you have a copy you'd be happy to sell or know someone who could help?
Thanking you in advance.
Manny
PS: Sorry, but I don't understand why the pics turn up upside down as they're not so on my desktop
A follow up on my original post above is that I managed to import a full 70's factory manual from a farmer in England. The mechanical intricacies of the 185/188 are seemingly identical to 165's upwards and only in differ in specs and tolerances due to larger parts etc than their smaller relatives. Happy to assist with spec info if this should be required.,,
2015 TRANSMASTER LOWBOY TRAILER (A52141)
2015 TRANSMASTER...
Case 1825 Skidsteer (Non Running) (A50515)
Case 1825...
2019 Caterpillar DP35N Forklift (A51691)
2019 Caterpillar...
Fire Hose W/Holder (A50774)
Fire Hose W/Holder...
2006 GMC C8500 Altec AM547 50ft Material Handling Insulated Bucket Truck (A50323)
2006 GMC C8500...
2015 Ford Fusion Sedan (A50324)
2015 Ford Fusion...
