massey ferguson 245 fuel filter change problems
   / massey ferguson 245 fuel filter change problems #1
denisereed
commerce ga
massey ferguson245
Changed the fuel filter out and having problems getting the system bled out.Fuel seems a little too slow getting to the filter and whats with these lines that don't seem to pull out of the housing.Wanted to flush out the lines as there was a lot of trash in old filter.
   / massey ferguson 245 fuel filter change problems #2
The lines don't usually just "pull out". They will require some effort. On most there is a slight flare on the end of the line just beyond the rubber sleeve. The sleeve gets expanded into the opening in the pump or filter base when the fitting is tightened. and won't simply slide out. When I need to remove one I expect to replace the sleeve because it usually comes out in pieces. Thye become brittle with age and often require being broken up with a sharp pick for removal. As for checking the fuel flow, you should be able to flush the lines well enough without removing them by turning the fuel on with filter removed and operating the supply pump. This should cover all but the final stage from filter to injector pump, which should not be an issue anyway if the filter did it's job.
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50774)
ALL TITLED ITEMS...
1986 VIM TACK TANKER TRAILER (A50854)
1986 VIM TACK...
2016 John Deere 35G Mini Excavator (A49461)
2016 John Deere...
2021 CATERPILLAR 299D3 XE SKID STEER (A51242)
2021 CATERPILLAR...
2014 CATERPILLAR 336FL EXCAVATOR (A51242)
2014 CATERPILLAR...
GARDNER DENVER 480 VOLT AIR COMPRESSOR (A50854)
GARDNER DENVER 480...
