Massey Ferguson 431 Lift Pump Trouble
   / Massey Ferguson 431 Lift Pump Trouble #1
Max Ray
Jacksonville Texas
Massey Ferguson 431 2004 model
I have a MF 431 with a perkins engine that the fuel lift pump is not making proper connection. The purple wire to the pump is hot but I dont know how its making a ground back throught the ignition (if thats what its supposed to do) I can jumper the pins on the pump straight to the battery and the pump works fine. Ive checked all the fuses and looked for any loose connections but cant get the lift pump to actuate normally. I use to hear it when I turn the key on but not now. Tractor will run at idle but misses and smokes when I try to work it.
Any help would be greatly appreciated.
Max Ray
2014 Jeep Grand Cherokee SUV (A51694)
2014 Jeep Grand...
CAT 336 D, Cab, Heat/Air Excavator (A52384)
CAT 336 D, Cab...
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
JOHN DEERE 560M LOT NUMBER 28 (A53084)
JOHN DEERE 560M...
