massey ferguson 6170 air conditioning
   / massey ferguson 6170 air conditioning #1
robert.taylor
Massey Ferguson 6170
How much freon is needed for a 6170 tractor
   / massey ferguson 6170 air conditioning #2
Whether the ac was on tractor when bought new from dealer or added later,non are STANDARD. Hose length ,different metering devices,size and a host of other details require charging by super heat or other means. Unless showed how by an experienced tec, ac charging is best left to a pro. Unintentionally introducing air, contaminates and moisture into system ultimately damages system costing more to repair than had charging been done right to begin with.
Sorry I rained on the parade but here's something everyone that wants to diy despite what I say can use. While installing new ac or during a repair that requires opening system,install a sight glass in high side line.
   / massey ferguson 6170 air conditioning #3
Robert
Welcome to TBN
Is AC not cooling any amount? Are you desiring to install refrigerant to an empty, evacuated system or add refrigerant to system which possibly contains some refrigerant? Do you have access to AC gauges that could be attached to AC system? Do you have a refrigerant scale?
John Deere 2640 2WD Tractor with 146 Front Loader (A55218)
John Deere 2640...
KUBOTA M5660 SU TRACTOR (A52706)
KUBOTA M5660 SU...
2003 VOLVO VNL TANDEM AXLE SLEEPER TRUCK (A54313)
2003 VOLVO VNL...
2597 (A54757)
2597 (A54757)
2020 McLanahan 150 TPH USP Sand Plant (A52377)
2020 McLanahan 150...
Peterbilt (A51692)
Peterbilt (A51692)
