Massey Ferguson 65 rear hydraulic problem
   / Massey Ferguson 65 rear hydraulic problem #1
JKDmo06
Fulton, MO
Massey Ferguson 65
I recently bought a Massey Ferguson 65 and added a rear remote kit by using the factory diverter valve. When the diverter is in three point mode, the lift arms work fine. I plumbed the top of the diverter valve into the positive port on a double action spool valve and then into a quick connect fitting, then did the same with the bottom of the diverter valve. When I move the valve lever there is action in the lines but not enough to do anything. Anyone have a suggestion?
   / Massey Ferguson 65 rear hydraulic problem #2
In an open center hyd system, all valves are supposed to be in series.
There should be unimpeded flow with all valves in neutral.
Gotcha...how can I alter my setup to make that happen?
   / Massey Ferguson 65 rear hydraulic problem #4
Open center hydraulics.
If your valve has PB, that will feed the next valve and so and so on.
If your valve does not have PB, then the tank port is sometimes used to feed the next valve.
Also be careful of using QD's in the hyd flow path. If one should become unconnected, you will dead head the pump.
Just be aware that the tank port on most valves is only rated for about 500 psi
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
LOT: Assorted Hammers (A59076)
LOT: Assorted...
New/Unused 14ft Bi Parting Gate (A57454)
New/Unused 14ft Bi...
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
200 Gallon Front Mount Tank (A57149)
200 Gallon Front...
